1 - 1 of 1 Posts
You all were so great with your advice on my engine problem I have one more question! I am putting in a 302 into a 1965 mustang. I was told I had to change the oil pan and the sump pick up tube . I discovered my tiiming cover had a hole on the passeneger side for the dipstick tube. which was plugged, I removed the plug and tried to put one of those aftermarket dipsticks and tube and it is too small, it falls into the hole. Is there a larger size diameter dipstick to for later model 302's?T
Thanks again in advance!!
1 - 1 of 1 Posts
