i have 1.7RR's on my GT-40 heads and after doing so i have a tick on the passenger side. i know its on the number 4 cylinder because for some reason it seemed to want 2 shims.... that was the closest i could get it.
is it possible to get a tick if they are too tight. meaning the pre-load is too much... i know it can happen if it is not enough (valve float). but this happens at all RPM's. obviously it gets faster as the RPM's climb.
what should i do? what would be the best way to adjust them? because it has 2 shims and only some of the others have 1 should i take a shim out to see if that helps? i have no idea why one cylinder would be that far out...
please help!
thanks,
adam
Discussion Starter · #2 ·
i have this problem too...on a stock rocker with stock heads...again #4 cylinder... no matter what i do...TICK TICK TICK
done this ever since i put the TFS springs in it
Discussion Starter · #4 ·
well i have double hydrolic valve springs on the heads that will handle a lot more lift than the stock cam (which is what i still have). im hoping there is nothing wrong with them. its odd because i had to put 2 shims under the rocker and most of the others didnt need any, or maybe 1 on 4 or 5 of them...
thanks,
adam
