i am cleaning up around my steering column, and i discovered that the wire coming off the ignition is the wire that makes the beeping sound when the key is in....
it is hooked up to some plastic that holds it on the ignition lock (which i took out of the car) i can take it off, but should i leave it off?
my question is, it is ok to to remove it? or does it have another purpose besides the annoying chime?
Find chime emitter and remove it. That will work too.
Stanman
