Formerly known as jbj302
So, I swapped this cam into my N/A 347 with 11.0:1 compression. I also upgraded my valve springs to the AFM high rev springs. Currently I have a timing set at 18°. It ran like crap at anything below that. I plan on putting it on a dyno soon but wanted to see what others have run and their results. Thanks!!
USAF retired
Spark would most likely depend on chamber in the heads
timing is handled in the ecm
adjusting base timing is a '90s thing that doesn't work cause peak torque is not the same with that cam
