does anyone know where to get some an fittings that will adapt to the stock fuel lines I have seen them to the stock fuel rails but I havent seen any to the stock lines. I need them to adapt to the spyder fuel rails thanx josh
Just bought a set from Down's Ford. They're in all the mustang magazines. $75 bucks for the two fittings. Bill
those are a waste of $$$$. just have your rails modified by welding on a an male fitting. this way later your just throwing away a $6 fitting instead of 75
You could also cut off the fuel inlet line on the stock rail. Drill it out with a 7/16th bit and tap in a 1/4 npt line which will allow for direct connection of -6AN line. There is a fair amount of meat on the box connector on the stock fuel rail to allow for a good seal. Just make sure you clean out all the metal filing and then clean it again.
