As you can see I got my amps mounted, everything works great, I am happy with the looks of the way they are mounted, but, wondering if it could look cleaner. I am looking for some advice or examples on what to do to clean it up even more. I am not ruling out the idea of moving the amps elsewhere.
I welcome simple suggestions and even more complex suggestions.
I will be re-mounting my Infinity Basslink in the trunk soon.
My only requirement, is that I am able to maintain most of the trunk space and still be able to fold down the seats other than that I am wide open to suggestions.
SN95GT50
Well, you could run the wiring through the seat backs (coming out on the bottom), so they wires aren't so exposed. That would do a lot for making it look cleaner. Or, if you were willing to go a little farther, you could actually flush mount the amps into the seat backs, so nothing shows but the heatsinks. That would look really nice.
You coupe guys think your so special with all that trunk space... I dunno - it looks good. I would tend to agree - the only way to make it look any cleaner would be to refine your cables even more - But doing any more than you have already will start getting tricky. I agree - if you want it to be cleaner - run the wires into the seat backs - And be sure to find trim pieces for the holes you cut - before you cut them (So you can be certain to make the hole work with the trim.) ...Other than that - Paint your mouting screws - they look out of place against the black Amp-chassis.
I like the idea of the wires into the seat, will need to investigate how to do that. Flush mounting them into the seat is a no go, wife would not like that, two kids, she would be concerned about safety.
I was also thinking about flush mounting them to the trunk floor directly behind the seats, or, building a shelf where the old sound box used to be. This will probably change on a monthly basis until I really like it.
Thanks,
SN95GT50
