1 - 1 of 1 Posts
01 Mustang GT, The 2 wire (green and yellow) plug that goes to the rear of the alternator is not connecting right which is causing the battery light to stay on and the alternator not charging the battery. have tried 3 different connectors and replaced the battery and the alternator and still doesn't work. applying pressure to the top of the plastic connector and pushing toward the alternator shuts off the batterym light and the alternator charges but if you let go of the connector, stops working again. Tried replacing everything and still can't get it to work. Anybody else have this problem?
1 - 1 of 1 Posts
