I just picked up a 94 Cobra and it has horrible alternator whine through the speakers. The setup is completely stock Mach 460 so I have no idea where to begin? Also, the whine isn't constant, occassionally it will completely dissappear for a while then come back. Could this be a faulty head unit? The previous owner said it was doing this before the MSD also, so I doubt that is the cause.
thanks
Mark
I am having the same exact problem. I have a 94 cobra with the mach 460 and i know it's not the head unit cause I put another in and it still happens. I notice when its hot or wet out it happens constantly. Anyone else have any suggestions ? thanks
i can unplug the amp for the front lower door speakers and the whine is completely gone, what does this mean?
I think it means you have a bad ground going to the 6X8 amp. Do check that connector behind the driver side kick panel. I have a 94 cobra with the Mach460 too. I used tie wraps to cinch this connector tight and the whine dissapeared.
Congrats on your new car, I have a blast driving mine.
Did u guys notice if there was a brown cable running to the back of the car while you were looking in the kick panel ? this is another issue but i did solve mine my looking in the kick panel and tighning up that connector. thanks for the help on that ...
Billy
Fixed mine by that connector in the kickpanel also, thanks guys.
