I have a 95 GT with the 94-95 Cobra intake. I am about to get AFR 165 heads and am wondering if the stock valve covers will clear them with 1.7 stud mount rockers? Also do you need a spacer for the intake and will this still fit under the stock hood? thanks for any help.
PMS Tuning Forum Moderator
If you go with stud mount roller rockers then you will need aftermarket taller valve covers. And b/c of that you will need to run a spacer under the upper intake to clear the valve covers. It will be close wether or not this will fit under the stock hood. I have pedestial mount heads with stock valve covers, no spacer under my TFS R intake and it all fits under the stock hood.
Troy
