will the anderson ford motorsport n/a power pipe for an 96-98 cobra work with my stock MAF? its not clear on their website if it work will with..or works only with an PRO-M shorty 80mm maf.
thx.
It will work with the Stock MAF.. You will need to buy an adapter to attach a filter on the end of the stock maf though.
I ran one for 2 years and I just now upgraded to the Pro-M 80.
thx for the info...can you tell me were to buy the adapter for the filter to work with my stock MAF? the filter is the one i can buy from AFM's site right? thx
You just need an adapter that will bolt to your stock maf that has a flange on it so you can attach a regular K&N onto it since most K&N's don't attach with bolts to your maf.
Accufab makes one, Pro-M makes one..
I cut this off Pro-M's site..
Filter Adapters 80/90mm cone adpt Plastic 12
70/75mm cone adpt Plastic 10
65mm cone adpt Metal 24
80/90 mm cone adpt Metal 24
70/75mm cone adpt Metal 24
Shawn
