I just tried to start my new 327 crate short block from central coast mustang and it has no compression, could this be because I adjusted my valves with out prelubing my eng and the lifters did not have any oil in them? So now when I cranked it up they fill up with oil and now my valves are to tight. Does this make sence
you did prime the oil pump first right? you can adjust the valve train with no oil in the engine but it sounds like your valves are too tight.
