I ran codes today and found that i have insuffiecient EGR flow and also high voltage to the TPS...so how do i adjust the TPS?
Discussion Starter · #2 ·
Discussion Starter · #4 ·
i thought i read in a post a long time ago that there was something you could do to adjust/fix it if your tps voltage was either high or low.
You might be thinking about where someone mentioned drilling out the TPS bolt holes. They are metal lined so it's not going to be easy.
