1 - 10 of 10 Posts
hey guys i have a question i ordered the C&L upper plentum with the BBK tbody but when i opened the package there was a accufab tbody instead of the bbk i dont know why they send me that but maybe they miss understood me it was the same price but the accufab is more by it self should i keep it or send it back and get the bbk i am not to familiar with accufab as they are new
but its a 75mm accufab billet polished aluminum .
Jurgen
Unless you're worried about having the emissions number on it, stick with the Accufab. If you need to pass emissions, you'll need the BBK.
I have heard the accuafab is a better throttle body. I would keep it to.
The Accufab is a better quality unit in my opinion. The biggest gains with the throttle body/plenum comb is just what you have now. The 75mm Accufab with the C&L upper intake plenum.
I wuold keep the accufab.but i think that bbk makes some good stuff.i got some bbk lt and had no problems.either way just keep the accufab
best way to get the TPS screws is with an impact gun. Come right out that way.
The screws on the TPS can strip REAL easy. I found best way to remove them was to take the TB off the plenum, wrap a towel around in and put it in a vice on a shop bench. Then you can get some leverage on the screws and zip them out. Even easier with an impact wrench.
Discussion Starter · #10 ·
i had 2 tbodys i tryed the first one with vice grips and one screw wouldt come of so i did the other one with a drill i put a screw driver tip on it and drilled it right out on the other tbody took less then a minute i hope this should make a good difference since i have P*P heads and cams and i am also gone install a PI intake we'll see becouse right now i run out of intake after 4k with the stock NPI intake
Jurgen
1 - 10 of 10 Posts
