ok i have a problem when accelerating in 1st and 2nd gears. my car is fine when i step on it from idle and lay on it up through the gears. but if i give it about 3/4 throttle to about 4000rpms then punch it in 1st or 2nd my car really hesitates like i hit the clucth or somethin for a sec then it goes.
im a newbie but my first thought was a bad fuel pump or injectors i think this may also be related to a problem that i have when i start up my car. it starts fine, then drops to about 500rpms, sometimes less, and either stalls or jumps back up to about 1000. it does this a couple times before it finds the right idle. when i try to fight the stall and give it gas right away the engine sounds like its choking and rumbles and kinda hops around between 500 and 1000rpms. whats going on here?
