Well, after my first post about this i was confident that the pressure switch was bad. I jumped it and the compressor still will not turn on. I cannot find power in the system anywhere. THe fuse checks out ok. After i jumped the switch, i checked the compressor clutch harness for power and there was none. The fan does not come on or anything. Any other ideas? Could the switch on the dash be bad.
Matt
If your fan doesnt turn on too, its probably your ccrm or the wiring. there is a great diagram in one of the post- search for it.
so check for power at the ccrm(the realy box behind the overflow can) at the right spots.
-Mike
The engine fan comes on when it gets hot but not when i turn the ac on. I thought the fan came on automatically when the AC is turned on. I am lost on this one......
i knda have the same problem just havent had time to tinker with it ,, let me know what happens with yours
