ABS delete manifold
1641 Views 3 Replies 3 Participants Last post by  Fill
Do any of you guys run an ABS delete manifold? I put one on my cobra when I switched to a solid rear axle and it does not seem like the back brakes are doing much work.
Did you have to change the proportioning valve? My pedal is also low as compared to before.
I have bled and bled and bled the brakes for the past couple days. I have fluid and no air. Just wondering if anyone else had run into this.
I literally typed this thread title into the site search engine and came up with 39 responses:
http://forums.corral.net/forums/search.php?searchid=8844788
Good Luck
and you're welcome
Your hyper link does not work. Already searched this. Most of the post on selling these blocks are from the guy I bought mine from. I was just looking for a little more info about my brake pedal feel. Thanks for nothing.
Bill,
Did you start with the master cylinder rear/front bleed screws? Most people report a stiffer feelling brake pedal after install. If your brake pedal is not hard, then there is still air in your line or a very small possible leak? When I installed my own delete manifold yrs ago on my 03 Mach 1, the pedal was firmer then with the ABS.
Phil
