As in the opposite side of where the wires go into the connector? Just want to be very clear on this before I start swapping locations and such. ThanksThey usually depicted viewing the actual connector pins....front
the side that does the connectingAs in the opposite side of where the wires go into the connector? Just want to be very clear on this before I start swapping locations and such. Thanks
I'm doing the reverse of that. I'm using the 91 harness and the box is from the 87 harness. Even if I can disregard the box from the 87 I'm still interested in what it is.If you are using the 87 harness , I would disregard anything from the 91 .
Remember 91 is the first year for air bags , so there are many things you will not find in the 87 harness .
low fluid moduleSo I'm pretty close to finishing up the wiring for the new harness. I pulled the 87 harness out and found this box that I don't have connectors for on the 91 harness. What is this box? Should it be in with the new harness I'm putting in?
So from what I see this is a 87-89 only applicationlow fluid moduleSo I'm pretty close to finishing up the wiring for the new harness. I pulled the 87 harness out and found this box that I don't have connectors for on the 91 harness. What is this box? Should it be in with the new harness I'm putting in?
Trust me I know, I'd like to know what he was thinking when he did all this he obviously didn't do any research. But anyways the ecm is now controlling the pump I believe (after I put the 91 dash harness back in) since it primes when I turn the key forward, is that the right thought process? He must have spliced into the pump for the toggle switch but left the wiring in tact to make the circuit to the ecm as well.If the ecm isn’t controlling pump, will be hard to diagnose
Ecm must receive crank/cam signal from distr to fire inj and run pump
Wow, you have one messed up stang, like to talk to previous owner
If you are measuring with a DVOM, this would be normal and not indicate a problem.So I'm getting voltage at both the positive and negative terminals of the ignition coil with only the positive wire hooked up to the positive terminal. Looks like somehow I got a short inside the ignition coil. How this happened in parallel to installing the new dash harness I do not know.
