Went ahead and did the research for you. Fix the jumper and no more fried ecu.The wires for the 02's and low oil did not change throughout the years, they are all in the same place.
The main ones you need to worry about are (on the harness end (ECU) that plugs into the 02 plug) is:
- 1. Lightblue / yellow
- 2. White / Purple
- 3. Purple / Yellow
The White/Purple & Purple/Yellow gets looped for a automatic ECU
The Purple/Yellow & Lightblue/Yellow for a manual ECU
Yes thank you!sent the wiring diagrams
I forgot to attach the pic.Ok I'm pretty sure I've isolated the problem. The connector right in front of the firewall which has the clutch sense switch wiring and signal return wire running through it is pinned wrong. I believe the female side from the engine bay is 1991 and the Male side that runs into the car under the dash is 1987 and they don't mesh. Does anyone have a pin out for both years or at least similar years. Like I said both cars were manual trans so both harnesses that I'm playing with should be manual, just a difference between the years?
Ya I'm understanding that now. I have the 91 wiring but it's also mangled. Do you know of a place to buy a whole new dash wiring harness? Or is there a good wiring diagram that I could use to re wire the 91 harness I have that isn't installed yet?One thing I found , having owned many fox Mustangs, is 91 is a bastard year for harnesses , probably because of the 1st year with airbags .
But only 91 works with 91 .
Bishko 1991 evtm bought and delivery expected Monday. Here's what I have to work with for the 91 harness I already have (over 50 wires loose from their connectors). If anyone has a better idea than trying to rewire the mangled harness I already have I'm all ears. It took me a while to get it even looking that nice it was all balled up and tangled in a box stored away.You need a 91 evtm, eBay should have one
Cannot trust any used harnesses in any event
I would verify the connectors have the correct pin orientation
that isn't that bad.....Bishko 1991 evtm bought and delivery expected Monday. Here's what I have to work with for the 91 harness I already have (over 50 wires loose from their connectors). If anyone has a better idea than trying to rewire the mangled harness I already have I'm all ears. It took me a while to get it even looking that nice it was all balled up and tangled in a box stored away.
