I have a 1987 GT that has mismatched parts from a 1991, the computer and engine are both 91. The car was running very rich and would not go to wide open throttle if I mashed the pedal to the floor but would if I very slowly pressed the pedal to build up to wide open throttle, it also seemed to idle well just rich as I had said. I tried to pull codes from under the hood using the test light method but got only a solid light (no flashes). With the help of some of these threads I was able to trace the problem straight back to the EEC and found that the trace wire for pin 46 was burnt. I had an electrical technician at work solder a jumper wire between the posts and replace the caps with all 16v 47 microfarrad (one original was leaking). So now the problem:
I put the EEC back in and now the car won't start. The fuel pump primes and the engine cranks but doesn't seem to fire it just cranks. So now that the EEC is fixed the car won't start does anyone have any suggestions? Or can someone point me to the right thread to start testing pins at the EEC/connector? Also, what may be related, are there certain wiring looms between the 87 and 91 that don't mesh? I am going to try and pull codes using the test light method again now that the SIGRTN wire is fixed and will update with the results from that.
Thanks everyone.
Thanks everyone.
