I am wanting to wire my A/F meter through a 3 position toggle switch so that I can view both 02 banks on the same meter, by flipping a switch. Has anyone done this before?
Yep, I mounted three gauges below the radio slot including an A/F gauge. it has a switch that is wired directly to the EEC harness then from the switch is a single wire to the gauge. Works well.
Where did you find a panel that'd fit 3 gauges there?
....me sooooo jealous.
I went down to Circuit City and bought a faceplate (the ones they use when there is an empty radio display hole). It cost about $13. I then drilled 3 2" holes equally spaced.
sweet!!!!! I have to do that!!!!
I tried using plexiglass, but kept either breaking the plastic or couldn't get the holes straight. any pointers?
