1 - 19 of 19 Posts
I went out to the shop and decided to crank the car it has been a few weeks since I drove it. I turned on the A/C to let it run. Heard a tink sound like a wrench hit the floor. I popped the hood to check it out. All looked fine......then the high pressure a/c hose blew. Oil everywhere.
Other than being old what makes a/c hoes blow? It was on my 89 hatch when i bought it in 2004.
I taped it up hoping to keep the moisture out. Do you think I will be ok just replacing the high pressure hose? Drier need to be replaced? What else would you recommend? I put a new drier on it last year when I charged it after the body swap into the 87 coupe
Thanks,
Russell
its possible someone put the wrong oil
or just a failure due to age.
if all the hoses are old, i would replace all of them
I think I still have the left over oil I will check the bottle. No telling what was put in it before I got it but it worked for over 10 years. Then it leaked down. I flushed it put new O-rings and a new drier, vacuum it and filled with r134a. About a year ago. I would guess about 2,000 miles
where was the leak?
when you converted to 134a you replaced all the hoses with new, right?
cause that fitting on the dis line is not for 134a
Discussion Starter · #5 ·
I never looked for the leak while the system was in the 89 body. I never had trouble with little leaks after I put it in the 87.
What type of oil should I use?
r-134a requires PAG
r-12 requires MO
PAG does NOT agree with MO
therefore if you have a system that had MO, and want to use 134a, you buy new virgin components
the evap can be flushed with rx-11, but that is it, the rest needs to be NEW.
Mechanical fan clutch or electric fan?
If you are running an electric fan, and it either is not working or you don't have it set to kick on when the A/C is on, you can blow a line when running the A/C and no airflow through the condenser.
the hoses are designed with a burst pressure much higher than the relief on the compressor
hoses should not burst like that.
Discussion Starter · #10 ·
It has an electric fan out of a Volvo running the Volvo relays. They have a ground trigger. It is not hooked up correctly. Right now it's just running through the GT fog light switch.
I didn't have the fan running so that might have been the straw that broke the Camel's back. Is there some way to test the blow off valve?
Where is a good place to tap into the a/c to turn the fan on?
I had custom lines built to except pressure switches
you will need to do the same
that hose failed prematurely, the relief is rated~450psig
if you test, it may not reset, and you will have to buy a new one
Discussion Starter · #12 ·
What's the second best way? That sounds expensive and difficult. I wouldn't know where to go to get custom hoses.
What does the existing pressure switch on the drier do? What about taping into the power on for the compressor?
Mine is the least expensive and most crude method, but it works
the switch on the accum is a low press switch, cannot be used for a fan
a micro controller that varies the speed of the fan and varies the capacity of the compressor is the best way
that is how modern cars do it.
if you want to tap into the ac request, that will mean when you are driving at freeway speeds the fan will be on, stupid
Discussion Starter · #14 ·
Is there a write up you can point me to, or details on how you did it?
I don't know enough about A/C how does the line pressure tell you vehicle speed?
I don't have an air dam under the core support, sometimes it needs the fan going down the road anyway. I know it needs one but I have not noticed any problems keeping it cool. Car is low in the front. Full weight 5.0 with 4 cyl springs.
I thought up my setup my self, its helps when my work teaches me the simple thermodynamic principles
designed it, built it
no wiring diagrams, no write up are made
It works of pressure, when the pressure is high enough, the fan comes on
if you are moving at freeway speeds, lets say over 40 mph......there is no fan that is going to produce that amount of cfm
i suggest you have the air dam installed, its needed
Discussion Starter · #16 ·
Do you remember what switch you used?
So the air movement keeps the pressure down? I am guessing you installed the switch between the condenser and orifice tube in the liquid line?
encapsulated pressure switch
i have various ranges ranges, i think 250-190 psig is one i settled on for 134a
Discussion Starter · #18 ·
I have ordered new hoses a new drier and a new condenser. I am going to flush the evaporator and drain the compressor. What weight PAG should I use?
I have used PAG 150 and 46, both double end capped
I am running 46 with a reman compressor now, as that is what the reman calls for
1 - 19 of 19 Posts
