Got her fixed, thanks for the input
bullitt2785 · Registered Joined Feb 28, 2007 · 578 Posts Discussion Starter • #1 • Nov 8, 2012 (Edited) Got her fixed, thanks for the input
donnie42091 · Registered Joined Jan 26, 2011 · 2,260 Posts #3 • Nov 8, 2012 Has the fuel filter been changed recently?
E everett2 · Registered Joined Nov 27, 2010 · 623 Posts #4 • Nov 8, 2012 Has the intake manifold been removed recently. I had the same symptoms and it turned out to be an intake manifold leak.
bullitt2785 · Registered Joined Feb 28, 2007 · 578 Posts Discussion Starter • #5 • Nov 8, 2012 New fuel filter, and yes new intake, but it was doing this before the intake swap. I'll check on the pcv valve Sent from my iPhone using Autoguide.com Free App
bullitt2785 · Registered Joined Feb 28, 2007 · 578 Posts Discussion Starter • #6 • Nov 9, 2012 Manifold gasket is good and new PCV valve...Still doing it. Anymore suggestions?
L LS1KILR · Registered Joined Jun 20, 2007 · 3,716 Posts #7 • Nov 9, 2012 cleaned the iac valve and maf meter? if so, check the fuel pressure when you very first start up the car
bullitt2785 · Registered Joined Feb 28, 2007 · 578 Posts Discussion Starter • #8 • Nov 9, 2012 Yes, both are clean and fuel pressure stays a constant 38-40 psi at idle
foureyed · Registered Joined Jun 17, 2008 · 763 Posts #10 • Nov 10, 2012 huesmann said: New wires too? Click to expand... Should be coil on plug. No wires
foureyed · Registered Joined Jun 17, 2008 · 763 Posts #11 • Nov 10, 2012 No codes? Do you have a tuner that you can look at fuel trims and O2s with?
bullitt2785 · Registered Joined Feb 28, 2007 · 578 Posts Discussion Starter • #12 • Nov 10, 2012 Correct, all new COP's Sent from my iPhone using Autoguide.com Free App
1wild90 · Registered Joined Dec 14, 2006 · 1,647 Posts #13 • Nov 12, 2012 bullitt2785 said: Got her fixed, thanks for the input Click to expand... what was the problem? My truck is doing the same thing.
