Just giving some thoughts to aerodynamics for my 2003 GT. What are your thoughts on spoilers / wings? I picked up a real Ford Cobra R wing but have not installed it (needs repaint). I have read that these really don't have any real contributing downforce but for $200 I figured I would snap it up. I have seen that Saleen sells a 1-piece spoiler 10-1108-B11961 and the American Muscle website states "it'll significantly increase downforce over your rear wheels for better performance". However, I do not see any statement like this on the Saleen Website. Steeda also has a "functional street wing" that has "high speed downforce" p/n 307-0005. I am not sure that I believe this as it has pretty much the same design as the none functional stock spoiler and it is in the same location. Then, there there is APR performance GTC-200 which is a legitimate wing, in the correct position and also costs upwards of $730.
My application is just open track HPDE. Not competition. My suspension is well sorted with MM K-member, MM control arms (with delrin), solid mount steering rack, adjustable tie rod ends, Steeda solid sway bar mounts, Eibach front (35mm) and rear (25mm) sway bars, mm camber / caster plates, full length SFC, MM torque arm, MM panhard bar, MM coil over conversion with Koni yellow single adjustable, MM strut tower brace.
Should I just go with a front splitter and ditch the rear spoiler / wing idea altogether? Or will a splitter without a decent spoiler / wing cause more problems?
Let me know what you think.
