coolant fan getting no power found blown fuse, replaced it fan worked for one day now fan can be jumped and works, fuses still good but no power at connector. please help!
Remove the fan connector and see if it is melted a bit. On mine and many others the ground contact heated up and melted the plastic. I believe there was even a TSB on this. Fix was to buy a connector at a junkyard and splice it in.
+1 Mine did the same...Two Rivers Ford In Nashville carries the piece...it's $23 dollars for a replacement.
