Your car has two sensors, one is for the ecu and one is for the dash. With a thermometer verify the temperature. I would also check the coil pack with a multimeter when it’s hot and cold and compare the numbers. Wouldn’t be a bad idea to do a compression test as the 3.8 has a tendency to blow head gaskets.
