Can someone please list out the highlights of the maintenace schedule for a 96 Cobra? I assume 96-98 is all the same. I need maintenance listed past 100k miles as well as below.
Thanks.
This is from the Service CD. It doesn't specify cobra in particular, it is just the general severe duty maintenance schedule found in the front of the shop manual for Mustangs.
HTHs,
Joe
Severe Duty Schedule
Note:
Rear axle lube quantities must be replaced every 100,000 miles (160,000 km) or if the axle has been submerged in water. Otherwise the lube should not be checked or changed unless a leak is suspected or service required.
For items marked with a number in parentheses such as (1), see footnote at the end of the appropriate maintenance schedule.
Note:
Severe Duty Schedule provides maintenance intervals for replacing the air cleaner filter if the vehicle is driven in severe dust conditions. However, the conditions which the vehicle is driven in may require even more frequent air cleaner replacement intervals than those shown.
l Check engine coolant protection, hoses and clamps once a year. (4)
l Every six months lubricate hood latch pivot points, internal contact areas and external hood latch areas that make contact with the hood striker. (4)
l Replace engine coolant every 36 months. (4)
Note:
Kilometer intervals are rounded off.
3,000 MILES (5,000 Kilometers)
l Change engine oil and replace oil filter (6731). (4)
l Adjust clutch by lifting pedal every 3,000 miles (5,000 km).
6,000 MILES (10,000 Kilometers)
l Change engine oil and replace oil filter. (4)
l Rotate tires and adjust air pressure.
9,000 MILES (15,000 Kilometers)
12,000 MILES (20,000 Kilometers)
15,000 MILES (25,000 Kilometers)
l Inspect engine cooling system, hoses and clamps; and check coolant strength every 15,000 miles (25,000 km) or 12 months.
18,000 MILES (30,000 Kilometers)
21,000 MILES (35,000 Kilometers)
l Change automatic transmission fluid.
24,000 MILES (40,000 Kilometers)
27,000 MILES (45,000 Kilometers)
30,000 MILES (50,000 Kilometers)
l Replace air cleaner element (ACL element) (9601). (4)
l Inspect engine cooling system, hoses and clamps; and check coolant strength every 15,000 miles (25,000 km or 12 months). (4)
l Inspect exhaust heat shields.
l Inspect front and rear brake shoes and linings (2001) and front disc brake rotors (1125) and rear disc brake rotors (2C026) (if equipped). (2)
33,000 MILES (55,000 Kilometers)
36,000 MILES (60,000 Kilometers)
39,000 MILES (65,000 Kilometers)
42,000 MILES (70,000 Kilometers)
45,000 MILES (75,000 Kilometers)
l Inspect engine cooling system, hoses and clamps; and check coolant strength every 15,000 miles (25,000 km) or 12 months. (4)
48,000 MILES (80,000 Kilometers)
l Change engine coolant initially at 48,000 miles (80,000 km) or 48 months. Therefore, change engine coolant every 30,000 miles (50,000 km) or 36 months. (4)
51,000 MILES (85,000 Kilometers)
54,000 MILES (90,000 Kilometers)
57,000 MILES (95,000 Kilometers)
60,000 MILES (100,000 Kilometers)
l Replace spark plugs (12405). (4)
l Inspect accessory drive belts (8620). (4)
l Replace air cleaner element. (1) (4)
l Replace positive crankcase ventilation valve (PCV valve) (6A666). (4)
l Adjust clutch by lifting pedal every 3,000 miles (5,000 km). (4)
l Inspect front and rear brake shoes and linings and front disc brake rotors and rear disc brake rotors (if equipped). (2)
63,000 MILES (105,000 Kilometers)
66,000 MILES (110,000 Kilometers)
69,000 MILES (115,000 Kilometers)
72,000 MILES (120,000 Kilometers)
75,000 MILES (125,000 Kilometers)
78,000 MILES (130,000 Kilometers)
l Change engine coolant every 30,000 miles (50,000 km) or every 36 months. (4)
81,000 MILES (135,000 Kilometers)
84,000 MILES (140,000 Kilometers)
87,000 MILES (145,000 Kilometers)
l Rotate tires and adjust air pressure. (4)
90,000 MILES (150,000 Kilometers)
l Inspect accessory drive belts. (4)
93,000 MILES (155,000 Kilometers)
96,000 MILES (160,000 Kilometers)
99,000 MILES (165,000 Kilometers)
100,000 MILES (165,000 km)
l Replace rear axle lube quantities.
l Inspect accessory drive belt. (4)
102,000 MILES (170,000 Kilometers)
105,000 MILES (175,000 Kilometers)
108,000 MILES (180,000 Kilometers)
l Change engine coolant every 30,000 miles (50,000 km) or 36 months. (4)
111,000 MILES (185,000 Kilometers)
114,000 MILES (190,000 Kilometers)
117,000 MILES (195,000 Kilometers)
120,000 MILES (200,000 Kilometers)
l Replace positive crankcase ventilation valve. (4)
(1) If operating in severe dust, more frequent intervals may be required.
(2) If your driving includes continuous stop-and-go driving or driving in mountainous areas, more frequent intervals may be required.
(3) At 60,000 miles (96,000 km), your dealer will replace the positive crankcase ventilation valve at no cost on 3.8L engines except California and Canada vehicles.
(4) Item for Emission Control Service.
It's nice to have the shop manual on CD!
Joe
