what size are the 96-97 cobra wheels? im thinking 17x8 but i want to double check to see if im right.
also, with these wheels on a fox what are the largest tire sizes i can go for front and rear without having any problems with rubbing etc.?
thanks!
17x8, run the stock 245 tires on them
They are 5 lug OEM only.
gruvee87vertgt said:
Keep your eye on the rims offset. You might need longer studs.
What does offset have to do with 94-97 cobra wheels and have anything to do with longer studs???
The 94-97 cobra wheels ONLY come in one offset OEM. Nothing to watch there!
Longer studs should not be required.
