what size are the 96-97 cobra wheels? im thinking 17x8 but i want to double check to see if im right.
also, with these wheels on a fox what are the largest tire sizes i can go for front and rear without having any problems with rubbing etc.?
thanks!
G
Same question for my fox. And what is the widest anyone has fit in rear of their fox. Anyone fit 17x9s either. Thanks
With a couple exceptions ('95 Cobra R and 2003 Cobra), all of the '94+ 17" wheels are 17x8" with a 5.72" backspacing (~ +31mm offset). The tri-spokes, Bullitts, Mach1s, Cobras, etc are all the same size.
With 17x8s you shouldn't have any problems with rubbing, since the biggest tires you should run would be 255/45-17s.
Plenty of people run 17x9s or even bigger. Scroll through the thread titled "Fox body wheel pics" (or something like that), which has a couple hundred pictures and examples of what will fit.
