Thought I would get more out of this car than I am, I need more home and family time.
This is a REAL cobra with a carfax report showing no accidents.
Body and frame have about 133k miles on it. Motor has about 5-600 miles on it since rebuild.
Interior is good shape and has normal wear.
Exterior, the car could use a paint job, just because of some sun fading, rock chips in hood lip, but front bumper has fresh paint. There is a dent in driver’s door low. The car is beautiful Rio Red.
Engine and Fuel System
347 stock block(balanced, line honed, bored and honed, etc)
Holley 650 dp
Full MSD system
Edelbrock RPM Air Gap intake(no machining done)
TFS stage 2 cam
Scat crank and rods
Canfield aluminum heads(no machining done)
IN-2.02 EX-1.60
Casting 18-350-61-1
DSS 1.6 roller rockers
Lunati Hyd. Lifters
Melling oil pump
7 qt oil pan
Girdle
SFI balancer
ARP bolts and studs throughout
BBK longtubes
BBK X pipe
Flowmasters into dumps
Sumped fuel tank
255gph Elec. pump
3 different filters
Adjustable Fuel Pressure Regulator
Radiator 3 core aluminum w/dual fan and shroud
Drivetrain
Borg Warner T-5(stock)
MGW shifter
3.73 gears
Centerforce clutch
Brand new Limited-slip
Moser 28 spline axles w/3inch studs
Brand new slotted Raybestos Rotors and pads all the way around.
New shocks and struts
New rack and pinion, ball joints, tie rods
Both front calipers are new.
Upper and lower rear control arms
Car is lowered
Wheels
Cobra r's
Brand new MT ET Drag radials on the back with maybe 150 miles on them
Extra's
Innovate motorsports LM-1 Wideband w/XD-16 digital logging gauge
Autometer Oil and Water-mechanical gauge included but not installed
Line lock integrated into cruise control and "ABS" dash light so you
know it's working.
Shift light integrated into the "Overdrive Off" dash light
RPM module
Driveshaft Loop
Full sub-frame connectors
Envoy Foglights to fill in the foglight holes
Asking $7,000 obo, willing to negotiate, since I am eager to sell. I ask that only serious buyers contact me, because I am not ok with people just coming for a joy ride. This car is fast and fun! Here is a link to a You Tube video I took of the car idling.
I have receipts and a build sheet from when the motor was originally built with an entire shoe box full of paperwork to show the history.
More pictures available if you want.
Thanks much and if you are interested contact Jason at 414-344-8544. Car is located in Milwaukee, WI.
