My 95 GT starts perfectly sometimes, but other times the starter clicks like it is about to start and then i have to push start it to get it going. After I turn it off it still wont start until I try again a few hours later.
I have replaced the starter a few months ago, and the ignition key switch because it was getting warn out. I bypassed the clutch start cancel. I made sure that Im getting 12V on the starter constant. The signal wire when I had it off was getting 12V when I turned the key also.
It seems at this point that it could only be the cabling going from the battery to the starter or I got a bad starter from Advance. The worst part about it is that it is intermittent as hell. Every time I get it up on the lift it seems to work. If anyone has advice please help a brother out.
Sounds like it could be a ground issue... Check all your grounds
