Well my 94GT is at the grocery store, the car was running fine, and has been. I parked, went in, came out and as soon as i pulled out of the space and went forward about 10 ft, it cut off. Its getting fuel, and is cranking hard, but it just wont kick over. Ideas? please? someone?
Michael
See if your getting spark. Pull off one of your wires and ground it somewhere you can see the spark. Crank her over and look for a spark. I bet you might have blown your TFI module. It's below/behind your air filter in a heat sink. Take it to any parts store, and they should be able to test it to tell you if it's bad or not.
Hope this helps.
Change the ignition module on the passenger side of the engine compartment that is screwed on to a heatsink type of thing.
I'm pretty sure thats the problem.
Banned
Reger99GT said:
could my crane Hi-6 box have gone bad?
It should be easy enough to bypass if you used an adaptor harness. Just unplug the harness and connect the stock harness to the coil.
check your fuse's this happens to me all the time
