Building up my 94 GT. Will be a track only car. It has mechanical gauges and a Painless harness for the headlights, starter, alternator and taillights. I will be spraying it with nitrous. I have questions about this T4MO computer and if I will be able to use it for this build.
Will the T4MO computer still work and fire up the car if I:
- strip down the ECM harness to only run the circuits I need? (removal of CCRM, ABS, EGR circuit, ect...)
- run external relays to the ECM and Fuel Pump?
Will the T4MO computer still provide fuel enrichment if I spray it with a small dry shot (50 and under) in my hypothetical configuration above?
I have a Moates Quarterhorse to use as for tuning if I can do these things and get the car fired up.
