· Registered
Last week I finally had someone replace the original balancer with the PowerBond PB1084SS purchased a few months ago. All the difference in the world! SO MUCH smoother from 3K RPM and up, see photos for the condition. I was aware these are known to go south and I was noticing some runout in the crank pulley. Better safe than sorry. I swear I have this "pedal feel" that it may be somewhat heavier than the original but maybe just the effect of better balance.. Wish I would have weighed the PB first and compared but I didn't.
And PS- Car is otherwise bone stock with 63K original miles.
Tool accessory Tool Rim Metal
Metal
Wheel Auto part Automotive wheel system Rim Bearing
· Registered
Discussion Starter · #4 ·
The balancer you listed weighs 7.6lbs....
Thanks for that, I would have thought it was just a little heavier. The Summit description says "In most cases they are only marginally heavier than the original cast iron balancer ...". I just weighed the original pictured above, looks to be ~8 pounds, but this is on a bathroom scale so ...
In any case I can't get over the huge improvement. Night and day. Used to be I couldn't wait to get out of 1st gear (with stock 3.08), now I like to let it stretch it's legs. Too bad it's about to go into hibernation here in Pittsburgh.
· Registered
1991 Mustang LX 5.6
I just located some conflicting info about the weight.It appears it might be closer to 10.9lbs,which would be around 3lbs heavier than the stock balancer you weighed.
· Registered
Discussion Starter · #6 ·
Call me crazy, I don't know. I'm 72. Not senile. But I sense the small additional weight - at the nose of the crank. How this all comes into play and affects overall engine balance I don't really have a clue. The Cobra does have a lighter flywheel. But of course the clutch is part of the equation is it not? When I purchased the car the clutch had already been replaced, with what I don't know. It works fine, pedal effort is okay, smooth operating. The OEM clutch was likely Cobra specific, was clutch weight specific? Beats me.
This all reminds me of a day back in the mid 70's. I was working as a Porsche+Audi service writer (they're service managers today) and the Porsche service field rep stopped in. Hard core German guy as you might imagine. He proceeds to lecture us about the polar moment of inertia of the new 924 model (I subsequently owned a 944 some years later, same car but evolved) as opposed to the outgoing 914. The 924/944 was front engine with rear transaxle, the 914 was mid-engined. Both were superior handling cars.
This was his explanation ... Imagine a barbell weighing say 10 pounds- with 5 pounds at either end. Place your hand in the center of the bar and try to twist the barbell = 924/944. Now move all the weight to the center as one weight of 10 pounds and do the same thing = 914. The 914 twists around itself, the 924/944 is totally the opposite. Why do I bring this up- it's a torsional twist equation.
I'm trying to grasp how it is okay to have a balancer that is heavier than OEM design. No complaints, I'd repurchase the same one in a heartbeat. But It seems that the crankshaft should have equal forces upon it at either end for proper balance- or "tuned" to be so. I'm not discounting the accessory driven parts, I realize that load is there. If someone can explain this to me in layman's terms I'm all ears. I must be overthinking this and missed a basic theory.
Photo attached of my Fastest Time of the Day car in 1973. Don't think Polar Moment of Inertia was an issue ...
Land vehicle Vehicle Car Classic car Coupé
