does this work?
what are the SN95 alt's?? 130amp?
how could i do this swap?
thanks
I've used a '94 GT 130 Amp alternator on my '90 for years and it works great. You just have to wire them correctly!
the newer mod motor alternators won't work because of the mounting hole location (both on bottom) i have a 130A that i got new off of ebay for $100. the mounting locations are on opposite sides, like the 2G stock alternator
thanks a lot i have been searching.. found a good page with a simple wiring diagram etc.
does the 94-95 alternators mount exactly where the 87-93's alt mounts? no messing aorund with that?
You have to grind away a little bit of the alt bracket to clear the 94-95 alt, but otherwise, yes it mounts in the same spot.
It's a very easy upgrade.
