Price is shipped each. I have these 4 plus another with the temp sensor hole drilled and tapped for a fox body. No port work.
Explorer won't work with a Kenne Bell. Some people want cobra parts. Otherwise, no difference.Other than the part number, is there any function difference between these and an Explorer lower?
why is that?Explorer won't work with a Kenne Bell. Some people want cobra parts. Otherwise, no difference.
the explorer lower relocates the upper either forward or backwards just a smidge which effects belt alignment.why is that?
but you can interchange between cobra lower and explorer upper or vicea versa?the explorer lower relocates the upper either forward or backwards just a smidge which effects belt alignment.
