my car was originally a 96 v6. its now a 95 gt. My question is would any 94-04 V6/GT clutch pedal assembly work with no modifications? I don't mind if my cruise control doesn't work. Just curious about the brake booster setup.
This space for rent
The V6 models were all essentially the same. There were some differences as far as sensor mounting locations but other than that, it'll go in and physically bolt up.
This space for rent
Not sure what you are asking. There is a jumper present in the dash harness near the pedal assembly in AODE cars. That jump is pulled when the PROPER 5 speed pedals are added, but the electronics on the newer ones won't be correct so I'm not sure what you have to do. You can simply leave that jumper plugged in but the car can start in gear without the clutch pressed in!
