It is a 93, 2.3L, stick. I have replaced both ignition coils, wire, plugs, ignition control module, fuel pump, fuel level sender, clock spring, exhaust manifold. Replaced o-rings on injectors, replaced fuel pressure regulator. Then deleted EGR and put fooler plug on it. I cleaned inside of intake - it was nasty. I sprayed MAF cleaner on MAF. New air filter. Put silicone grease on everything. I ran codes, got 11, 111, 332. I believe 11 and 111 are the ok codes and 332 is the EGR. When the reader gave me the 10 code, I pushed gas pedal to the floor and let up. Car started up multiple times yesterday and drove great. This morning cranks but no start. During the past weeks , 90% of the time all it will do is crank and not run. Every now and then it will run. I am ready to loose my mind.
