1 - 8 of 8 Posts
93 5.0L GT Manual Conv
Hello;
I am coming to you for some advise/ideas for my no crank situation with my 93 Mustang GT. I have tested the battery with a load tester and it shows "good battery". I have changed the starter motor, solenoid and both positive and negative battery terminal cables. I have also changed the ignition switch on the right side of the steering wheel and the computer/ECU as well. I do need to specify that the new ECU is a mega squirt by DIYautotune. The reason for me changing the computer is due to my research of this no crank situation. I found out that the cause of my dash not lighting up the "check engine" light was due to a bad ECU. So that’s why I purchased the mega squirt. I did go thru the first screen of the setup and I installed it in my car but I still cannot make the engine to crank. I only hear a click and nothing else. I am providing a picture to show you my dash. Does anybody has any suggestions to my no crack situation?? Thanks in advanced.
lol easy, either the starters bad, the solenoids bad or the engine is locked up
btw ecu cannot cause a no crank as it doesnt control the starter relay
  • Like
Reactions: massacre
Post pictures of the starter solenoid and starter wiring.
Discussion Starter · #8 ·
Gentlemen;
Thank you for your help. The cause was a broken connector at the starter relay. I had t change the entire cable. I used the cable that came with the starter since I was using the original cable. I want to thank specially "BigDumpRedneck" for his suggestion to post pictures of the starter wiring. I made an idiot of myself not checking my own work.
1 - 8 of 8 Posts
