Hey all, I have a 93 LX with stock motor that has developed a rough idle. The engine rpm is slightly higher than before and is definately rougher...sounds like it has a cam in it now. When I give it some gas or begin to drive it seems to clear right up. I tried cleaning the MAF...I recently cleaned and re-oiled my k&n. I didn't completely remove the meter, just removed the hoses and wiped it out. Should I have removed the electrical connections and cleaned them? I also removed and cleaned IAC. I have noticed the fuel pump is very loud. Any other ideas as to what would cause a rough condition only at idle or lower rpm's (<1,000)?
I should mention this car has 188,xxx miles on it but does run very well.
Discussion Starter · #2 ·
mine does that as well with the exception of the high idle. Mines idles at normal its just rough. I have been wondering if the injectors may be dirty or maybe its leaky. I did a tune up and all the plugs were white to tan and fuel mileage is good. I dont have a wondering or searching idle so I am kinda in a f unk to solve this.
Allen
