What did you do with your coolant lines that run to and then from your stock egr after putting the intake on? An the vaccum line that plugs under the factory upper intake on the front from the smog pump cause the cobra one, there is no where to plug in. Same thing on the egr coolant lines, theres a way in but not a way out. Thanks for your time.
plug the coolant lines off.
put the vacuum line on the tree, you have to move the vacuum tree from the stock intake to the cobra.
take care,
adam
Would it be fine to put a coupling in between the two coolant lines and just let it flow straight through? The vacuum tree was the same. Three total plugs, all facing towards the rear of the intake. I got all of those but there was a plug made into the factory intake facing forward, theres not one on the cobra one. Again thanks for you time.
well anywhere you can hook the vacuum line up to works. vacuum is vacuum no matter where you get it from. so find or make a spot (with a T) and use it.
the lines can be connected together. thats fine. or just block them off. doesnt matter.
take care,
adam
Thanks Adam.
youre welcome
