93 Cobra 363ci 6speed build
37067 Views 217 Replies 26 Participants Last post by  Str8ballar
My 93 cobra #4275 weight 3540LB
The Plan, Build a really nice daily driver keeping it looking as stock as I can. Many build a DD including me thats fast low 11s high 10s but not really dependable at that level. This time I'm hoping to make it more dependable.
Old build
My 93 Cobra build GT40 heads
Long term build
Dart Block 363 Trick Flow 205 11R heads Long Block build by FordStroker.com (Have)
Innovators West Balancers (Have)
T-56 Magnum 1st 2.66 6th .063 (Have) Swap info thread below
T56 Magnum swap in Foxbody info and input?
Drive shaft 3.5in Aluminum 2 piece slip yoke, Aluminum flange (Hanlon Motorsports) (Have)
Crossmember (Stifflers) (Have)
Driveshaft loop (Stifflers) (Have)
QuickTime Bellhousings RM-8031 (Have)
Clutch McLeod RXT Twin Disc 1000HP Clutch (Have)
Clutch Fork (M-7515-A) (Have)
Speedo cable Part#'s Y869 (Rockauto.com) (Have)
McLeod Aluminum Flywheel (Have)
Maximum Motorsports Aluminum Clutch Quadrant (Have)
Maximum Motorsports High Performance Clutch Cable (Have)
ARP Pressure Plate Bolts (Have)
402897 - Prosport Spark Plug Wire Boot - Black) (Going to slide this on the cable to help keep the heat off it and the speedo cable) (Have)
Stock Air Box (Have)
Megasquirt PNP (Have) (Stinger MS3)
C&L 85mm Mass air (have)
80mm BBK Throttle Body (Have)
Cobra intake ported 80mm TB opening (Have) BigDogs Porting on Facebook did port work. 326cfm Average This is his stage 3
42 pound injectors (Have)
Nitrous kit (Have) (Nitrous Express fogger) single stage 175shot NOS 73 Fuel 23 jets
Nitrous Express secondary fuel cell (Have) VP NO2 fuel
PA Racing MOLY K member Rack and motor mounts 3/4in drop (Have)
4.1122G motor mounts give a 3/4in lower than stock (Have)
4.1104G Transmission mount 1/4in lower than stock (Have)
Exhaust is RCI 1 3/4 long tubes and 3in H pipe, 3in magnflows and 3in out the back. (Have)
Gears 331 (stock tire size 26in) (Have) May go 308s
31 spline axels and TrueTac (Have)
340lph T fuel pump (Have)
strange 10 way adjustable front and rear shocks (Have)
Electric fan (Have) Mark 8 fan with DCC controller Part# FK-75
MSD 6 Plus with 2 step and timing retard (Megasquirt controls this now)
Baseline Street launch upper and lowers (Have) set at 2deg
Mickey Thompson ET streets S/S tires 315/35r17 on 10.25in 93 cobra replica wheels (Have)
93 Cobra with 93 cobra replica wheels 315s
Want to keep it looking stock looking under the hood thats why the stock cobra stuff. Want to get High 10s out of the build. Would love more but would be happy with that. Am not going to turn more than 6,800 rpm on the car max. Thinking more like 6,300 rpm's.
Thought I would post my engine build (Fordstroker built)
I'm hoping for 500HP NA but I built this motor for 1,200hp+.
Dart SHP 363 Internal Balanced, Trickflow 11R 205 heads 66cc (Fel Pro MLS 1134 Head Gaskets). 10.1 compression
RPM 4340 crank, Scat 4340 H Beam Rods, 2618 Forged Wiseco Pistons, Wiseco's GFX ring. Motor is good for 9k rpms if I used solid lifters (I'm not) was told 7,500 with hydraulic lifters.
Custom cam for NA (Idle to 6,500rpms) Int .574 Exh .571 Dur @.050 Int 224 Exh 234 Lobe 112
8 way adjustable SA Gear billet timing chain with a torrigton bearing
Morel HYD roller link bar lifters. (5323)
3/8 pushrods 4130 Chromemoly
Jesel shaft rockers (They only make one for the 11r heads) (KPS-470191)
Moroso Oil Pan with billet end seals
Melling Standard Volume Oil Pump (10687)(I didn't want a high volume pump)
Moroso Oil Pump Pick up (24516)
ARP Billet Oil Pumpshaft
New timing cover
Edelbrock Water Pump (8840) (He is going to cut the tip down to 3/8 to help fit me electric fan)
All ARP bolts (All of them I know its a little extreme) LMR make a kit for the timing and water pump
All Fel Pro gaskets
I have no problem with you posting if you think I should do something different or ideas on my build. Its just a toy and I want to have fun with it.
Before
Land vehicle Vehicle Car Engine Auto part
After
See less See more
2
21 - 40 of 218 Posts
Was looking at picking up a TKO 600 from a guy. He told me I could shift the transmission in the car so I went to his house car wasn't running he was changing intakes. So I told him just hit me back when it was running. Guy got it running then backed out. After 2 months of talking and one trip to his house 60 miles away.
I was really looking at an A5 so I guess that will be my plan again.
The A5 that Tony sells is awesome. I've built quite a few of them, one guy lives in Alabama that has one I built for him before he rotated out of the service up here. He told me it's still going strong in his hot street car. They shift so smooth, but they are noisey.
Motor is ordered they said April or May.
Think I'm going to go ahead an pickup a PA Racing K member. He said he could build it just the way I want it. I added convertible motor mounts and it dropped my motor 1/2in (on last build) so I'm thinking If I get him to drop it 1in. That would give me 1in more (1 1/2 total) if I use the convertible motor mounts total or 1/2 more (1in total) if I use stock motor mounts. Going to use their A-Arms with spring perches so I can use my stock springs.
So few things I'm looking at.
I was debating to way to get the most air N/A and still look super clean so my thought is keep the cold air intake or go back stock box.
So the stock box has a outlet of 3 1/4in with the inlet being the complete fender hole. Plan on going with a 85mm mass air 3.34in inlet not sure outlet yet but the stock elbow is 3in. 75mm TB will be 2.95in
If I keep my cold air intake it is 3in in and out.
My plan is to go back stock but I will test both on a dyno.
I will also test the stock 65mm and a 75mm
My plan is to use the normal air box when daily driving but when I go to tune on WOT I will just come straight off the TB.
So I ordered the 85mm Mass air as I talk about above see in pic. I will use the air filter when I'm running at the track right off the TB. (This is for an 03-04 Mach 1)
https://www.americanmuscle.com/cnl-82maf-rai-0304-mach1.html
Also went a little overboard and ordered all ARP bolt. LMR has some really cool kits that they didn't have 15 years ago when I built my last big build.
https://lmr.com/item/LRS-10313HDW/mustang-engine-accessory-bracket-hardware-kit-8593
Woody is using this one when adding my timing chain and water pump
https://lmr.com/item/LRS-8501BHDW/1979-93-Mustang-50L-58L-Water-Pump-Timing-Cover-Studs-Bolts
ARP Intake Studs 354-2103
ARP Valve Cover Studs 200-7602
ARP Header Bolts 400-1110 (These are the 5/6 heads to help clear the headers) (I have Studs I will use on both ends)
Ordered a new K&N for the stock air box.
See less See more
Car and build looks good!
  • Like
Reactions: 1
All Choked Up
Thought I might post a couple pictures of my DD 363. Too small Cobra intake (ported lower), too small XE274HR cam, too small AFR 185 Outlaw heads (upgraded 8019 springs) Woody built the shortblock with my used Scat crank, and RPM rods. The idea was to build a nice streetable combo with mostly parts I had laying around.
Hope this is some inspiration OP!
Engine Auto part Motor vehicle Fuel line Automotive engine part
Engine Auto part Automotive engine part Fuel line Automotive super charger part
See less See more
2
  • Like
Reactions: 2
Have you put it in the car yet? Dyno or track numbers? N/A or ? Man I'm pumped.
I just took the pics last night. I've been taking my time with the details, just got the valvetrain set up this week. LGM 1.7:1 shaft mounted rockers, lifters are Morrel link bars, pushrods at 6.250" long. It will be naturally aspirated, aprox. 10:1 static compression, I haven't yet bought the PRO-M Engine management system I'll be using.
I will take it to the dyno when she's ready. Stock T5, won't be running at Byron with that.
Jay
  • Like
Reactions: 1
Jay
Can't wait to see your numbers. Looks like with those heads will work great.
Ordered my radio from post #4 and 6 new speakers. Hope to get started on the radio and new carpet in the next few weeks. You know the old saying (If it was easy everyone would do it).
Going to use PA Racing K member so this is my thread asking for help on how custom to order it.
This is the last major piece of the puzzle. (Thanks for any help you can give)
https://forums.corral.net/forums/drag-racing/2485654-pa-racing-k-member-choices.html#post18522356
So I'm at home and just as I expected the 85mm it its smallest point is 82mm or 3.22in so it will work just as I had planned. Hope to do a ton this week so pics are coming.
So did get much done today on my build was helping a friend cut his rear end down.
But went to another friends junk yard and got the right sensor for the 85mm being it was made for an 03-04 mustang. Took a min to find one. As you can see I cut the inside out didn't need it. Its just for looks anyway. Will work more on it tomorrow.
See less See more
2
So got a few measurements so you can see the size of everything as you can see the mass air is way to big to fit so I had to boil some water put the rubber ends in it and let them soften so it would stretch then one I put it on I kept it on till it cooled off so it would form to the new size see pics.
See less See more
4
Few pics of how it all turned out after it was done.
The stock air box is new had a cold air on it before just need to order and add the original sticker.
See less See more
4
  • Like
Reactions: 1
So I thought I had ordered ALL the carpet for the car once I open the box I learned I only ordered the back but I installed it today this was very simple only 4 screws. If you look at the back seat you can see a big difference in color.
Plan on ordering front carpet tonight.
See less See more
3
Just a pic of the parts that I'm working on adding. Some stuff is for the motor.
See less See more
Added the speakers today. Dash speakers didn't fit great but it will work. The one down side is I bet I added 5lb to the car they weigh a bunch more. Added some tape to the connectors thought it may cut down on noice.
See less See more
4
Few more speaker pics and the ones with the tape.
See less See more
3
While I was in the doors I knew the Actuators were bad but man they wounded move at all. Ordered some new ones today. Also paints my Lower controller arms did like the red didn't want people to look by the tire a see them sticking out (RED) so I painted them black.
See less See more
3
