1 - 10 of 10 Posts
90 LX 5.0 Hatchback f/s or f/t
Engine
-D&D Motorsports 306 Short Block
-Edelbrock Performer Aluminum Heads (Ringed)
-Forged Pistons
-Forged Steel Crank
-Lunati Cam (542 lift, 242 duration)
-Lunati 1.6 Aluminum Roller Rockers
-ARP Bolts and Studs
-Double Roller Timing Chain
-Comp Polymers Lightweight Valve Covers
-Cobra Upper/Lower Intake Manifold
-Holley Adjustable Fuel Pressure Regulator
-255lph In-Tank Fuel Pump (what I was told)
-Canton 7 Quart Base Pan
-BBK Ceramic Coated Equal Length Shorty Headers
-BBK 65mm Throttle Body
-Pro Flow 75mm MAF
-C&L TruFlow Inlet Tube
-FMS 30# Injectors
-FMS High Volume Oil Pump
-MSD Pro-Billet Distributor
-MSD 6A Ignition Box
-MSD 8.5mm Plug Wires
-MSD TFI Blaster Coil
-K&N Panel Filter
-K&N Valve Cover Breather
-Summit Aluminum Overflow Tank
-Hurst Short Throw Shifter
-Energy Suspension Motor and Transmission Mounts
-Griffon Aluminum Radiator
-Flex-A-Lite Black Magic Electric Fan
Electronics
-Auto Meter Sport-Comp Water Temperature and Tach
-Auto Meter Pro-Comp Liquid Filled Fuel Pressure Gauge
-Auto Meter Phantom Oil Pressure Gauge
-Auto Meter Pro Shift Lite with Pills
-NOS Wide Open Throttle Switch
-NOS Nitrous Pressure Gauge with Adapter
Power Adders
-NOS Big Shot Plate System (Stage 2, 150hp)
-NOS 10lb Bottles (2)
Body
-4” Fiberglass Pin On Cowl Hood
-Subframe Connectors (Welded)
-6 Point Roll Cage (Welded)
Wheels/Tires
-Weld Racing Draglites
-165R15 Front Tires
-255/60R15 Rear Tires
-5 Lug Conversion
Exhaust
-Flowmaster Mufflers (2 Chamber)
-Offroad H-Pipes
-Exhaust Dump Before Rear Axle
Dress Up
-Convoluted Tubing
-NOS Bottle Blanket
-Removed A/C,EGR, and Airbag Sensors
-Kirkey Roll Bar Padding
-MSD Cylinder Markers
-MSD Pro-Clamp Spark Plug Wire Seperators
Im looking for a 90-93 gt hatchback or an lx with t-tops. Mods would be nice also. Im not sure what to ask money wise. My car only needs a new clutch which I have just not installed, new skinnies, and one new nitrous fitting. My car is my daily driver has the stock t-5, Im not sure how many miles are on the t-5 but there is only a little over 15k on engine.
send me info, how many miles on the car?
original paint?
dents?
rust?
asking price?
[email protected]
1 - 10 of 10 Posts
