Posting for a buddy. Please Call him directly
--> Scott Parker at 937-875-5287 or Email -->> [email protected]
Located in Troy, Ohio (10) miles North of Dayton.
It has about 75K miles and is an ex-four banger. Has a fair paint job in bright orange with grey interior and black cloth race seats. It has lost a lot of weight... including all engine excesseries but a 95' GT style alt. and has no ventilation system. But otherwise has a full interior.
Engine runs great, and sounds awesome. Moroso 7 Qt pan leaks a little bit. And rust is starting in the left rear quarter behind wheelwell. Engine is a 306 with factory comp. I think it was built by Performance Clinic.
Car was recently dynotuned at Dayton Performance and made 307rwhp and 299rwtq. This car turns heads anywhere you go and is always earning compliments.
Only reason I'm selling is to make a down payment on an 03'-04' Cobra or a new GT. I'm currently asking $$6500 OBO 937-875-5287 -Scott Parker
-ENGINE- Canfield heads on studded block Hyland Sharp rockers on adj. studs Trick Flow Stage 3 Cam Victor 5.0 intake w/ 1" spacer ( May soon be trading for a RPM ) MSD Billet distributor 70mm BBK throttle body and EGR 80mm PMAS mass air (NEW)
-EXHAUST- Long tube headers Off-road H-pipe Mac Pro-dump mufflers -SUSPENSION- Tubular K-member w/ a-arms 90/10 struts w/coilovers 50/50 shocks Drag springs in rear with air bag Adj. upper control arms Megabite lower control arms
-DRIVETRAIN- Solid motor mounts Spec clutch 3550 Tremek tranny w/ Hurst shifter Aluminum driveshaft 8.8 with spool and 33 spline Moser axles C-clip elim. and heavy duty wheel studs Newer Weld draglites
-FUEL- 225 Lph pump factory lines and filter factory fuel rails Aeromotive fuel regulator 24# injectors
-ELECTRICAL- Newer 140amp alt. Optima Red top battery in trunk Electric fan Autometer 5" Phantom tach " 2.25" " fuel pressure gauge Innovate wide-band oxy. senser w/ gauge SCT chip w/ 7 position switch
-INTERIOR- White face gauges and vent controls Black cloth road race style seats (unknown) Simpson 5-way drivers harness Misc. aluminum trim peices -BODY & OTHER- frame connecters Newer headlights and clear marker lights 85' taillights Weld Draglite wheels 3.5" in front with 8" rear with 275/50/15 M/T drag radials
Here's a link to a bunch of pics!
Click HERE to see 90 Coupe For Sale
i will call him in a few days if he still has it...nice car...do you know how bad the rust is?
