1 - 20 of 39 Posts
1989 coupe 351 w roller motor bored .030 probe 2618 forged flat tops with eagle h beam rods z cam ported and polished canfield alum heads with 2.02 and 1.60 valves power products upper and lower that was opened up to use a felpro 1262 int gaskets. Rotating assembly was balanced sfi balancer and sfi steel flywheel canton pan girdle and windage tray 75 mm tb 80mm mass 30 # injectors andersonpower pipe and egr deletepump. Pump gas friendly 10.7 compression cometic head gaskets, arp head studs and fasteners mac 1 3/4 long tubes with 3 inch pro chamber and dumps. Lakewood scatter shield, perf clutch tremec tko trans alum driveshaft and safety loop sub frames south side lowers and uppers 15x10 w 6inch backspacing welds on the back and 15x3.5 up front d and d tubuler k member and lower control arms 90/10 and 50/50 lakewoods with coilovers in the front ps with bumpsteer kit car has ac but comp is no good griffin alum rad. Electric fan runs at 170 all the time very driveable and pump gas friendly has pro 5.0 shifter interior is clean and good shape manual windows and locks everything works windsheild washer reverse lights has all orig sheet metal no signs of any previous wreck damage. The motor should make an honest 400 to 450 at the flywheel also has nos big shot platesystem that is capable of 150 to 300 horse not installed yet. The car runs extremely strong has 100 amp alt new head lamps and carpet. Car has a black 3 inch cowl hood is reddish orange with tan int with black carpet. The car has about 3,000 miles on the motor and 148,000 on the body.
ASKING $6000 OR OPEN TO TRADES PLUS CASH[/B]******SOLD******
what gears in the rear/ axles. Is the fuel system stock other than the injectors. any pics of under-carriage and inside trunk
+1 on the under-carriage pics(core support). Also what color is that? Is it a clear coat paintjob or single stage? With the front bumper cover are those water spots or does it need to be repainted?
Discussion Starter · #11 ·
Yer i do have a pic of the undercarriage. I will try and get to it tomorrow. We are making plans to go to Orlando for the weekend. The car has a 3yr old paint job. It is going to need some paint. If i still have it after the 1st of the year it is going to get repainted and the intrerior is going to black. The color is a reddish orange. The car runs very strong. Motor was professionaly done in J'Ville.
Are you in Jacksonville?
1 - 20 of 39 Posts
