Here it is: My 89 Coupe that I just rebuilt 2 months ago. RECEIPTS FOR NEARLY EVERYTHING. but do have receipts for rebuild on engine
I am also interested in trades for a nice Truck or SUV.
I would like $7500 pretty firm but can move slightly.
Here is the break down:
1989 Coupe; converted from a 4 cylinder
Right now; it probably makes around 410-430 RW; no tune on it since I am still breaking the new motor in. have a lot of miles to go
This car was converted last year (May, 2008) from a 92 CHP donor car
- At the time: it received New carpet and headliner.
- The seats are out of an 85 GT with no headrests; they have been recovered but have a wear mark on the driver seat by your legs and not in the normal side spot.
- The car also received BRAND NEW A/C parts and Heater core using R-12 so it's icey cold. -> I just noticed a leak yesterday and will the buyer will more than likely have to have it recharged. (09-28-2009)
- Also, I bought an polished S-trim and stuck that on as well.
By the winter time, it blew the the front crank and rear main seals so I rebuilt the motor this year. You can see the rebuilt stamps on the motor, from my engine builder, on the back of the block. I also have receipts for all the new parts that went into the engine like rings, oil pump, gaskets, etc.
Since, I tore it down this Spring, I decided to add a bunch of parts. I have receipts for almost everything.
Exterior is an 8 out of 10; a few marks and 2 small dents but it is straight as an arrow
Interior is a 9 out of 10; because of the wear mark on the seat
New Parts added June 2009.
Transmission:
Tremec T5-Z
Ford motorsport aluminum driveshaft
Pro 5.0 Short shifter
Centerforce Dual Friction clutch
RAM Billet Steel flywheel
Steeda Adjustable cable and firewall adjuster
Supporting:
36 lb. injectors and 255 in tank pump
MSD 6Al with Boost / timing retard control
MSD Blaster Coil
Taylor plug wires
NGK plugs
New / Newly Added parts as of June 2009.
- Rebuilt 302 with forged pistons, stock bottom end; fully rebalanced and cleaned; deburred, new oil pump, etc....
- Rebuilt and ported Ford Motorsport Y302 Alum heads with upgraded TFS springs, New Valves, and all new parts;
- Custom Hi-Tech cam -> will provide cam card to buyer
- UPR Plated valve covers; clearanced for roller rockers
- Edelbrock RPM 1 intake
- BBK 70mm Throttle Body and EGR
- UPR polished Rad cover
- Marathon battery
- Mishimoto 3--row Rad
- Dual Contour fans
- 140 amp G-3 Alternator (purchased 07-18-09)
- Scorpion 1.72 Rockers plus new lifters and hardened push rods
- ARP Head Bolts
- High Flow Water Pump
- New Harmonic Balancer -> needed because old one was actually separated. The only thing keeping it from flying off was the lower blower pulley
- Dual-Nozzle AIS Methanol Kit
Converted to 4 wheel disc breaks
- Fronts are Stoptech rotors D/S with Hawk Pads
- Rear is out of an 88 Turbocoupe with new Eaton Posi and 3.73's
- Steel Braided Brakes lines up front
- Maximum Motorsports 4 wheel disc line conversion kit with Wilwood Prop Valve
- All new KYB shocks and Struts
- J&M Upper and Lower Control arms - subframes coming soon
- Comp Engineering Bump steer kit
All new cobalt gauges for Boost; Water Temp and Digital Tach. ; this setup cost me around $600 for just gauges
Innovative LM-2 Wideband - not even installed yet but have it there
Stereo alone cost me around $1,500 and is killer:
- Alpine XD-305A ->
- Sounstream Reference 5-channel Amp
- Kenwood 5-way 6x9's in the back
- Diamond Audio D3 10" sub in small sealed box
- Boston Acoustic 5 1/4" speakers in doors
- Boston Acoustic 3 1/2" components in the dash
New Exhaust:
- FMS stainless Shorty headers with Stage 8 locking bolts and new Percy Alum exhaust gaskets
- Bassani Stainless Catted X-pipe
- Flowmaster American Thunder system
- Magnaflow 3" Stainless LX tips
Wheels:
16" ROH Spyder wheels
- New 225/50/16 tires up front
- Nitto 245/50/16" DR's in the rear -> can provide NEW in wrapping Toyo DR's for the right buyer ($330 value)
Transmission:
Tremec T5-Z
Supporting:
MSD Blaster Coil
Taylor plug wires
NGK plugs
- Marathon battery
- Dual Contour fans
- ARP Head Bolts
- Alpine XD-305A ->
New Exhaust:
Wheels:
