I have an 88GT for sale. It is a rolling chasis. All wiring is in car, but no motor or tranny. All parts on car are Brand New 0 miles with exception of hood. Nothing wrong with hood, just not brand new. Price is $3800. Rear End and Roll Cage are worth this ALONE.
1988GT Black with titanium ground effects
5speed car (no tranny obviously)
Mass Air Converted
All EFI wiring still in car
No AC stuff in car
4" Harwood Lift Off Hood, already installed and fitted
Car has one tiny ding on passenger side fender, other than that body is perfectly straight
Car could use paint, Hood needs paint.
Front Suspension:
UPR Tubular K-member
UPR A-arms
QA1 Coil-overs w/ 135lb springs
QA1 12 way adj struts
QA1 Caster/Camber Plates
Flaming River complete Manual Steering setup (rack and shaft) w/ poly bushings
Aerospace lightweight drag brakes
Stainless Steel Brake Lines
Rear Suspension:
UPR Double Adj. Uppers w/ solid bushings
UPR Single Adj. Lowers with solid bushings
UPR Anti-roll bar (not installed)
QA1 10way adj. Shocks
Welded Torque boxes
9" ford housing from Currie
Mark Williams Nodular Iron Center Section and Aluminum Pinion support
4.30 gears
Custom aluminum driveshaft by inland empire driveline
35 spline mark williams axles and locker
Poly busings in rearend
New GT springs w/ poly retainers or whatever they are called
Custom Sub-frame connectors that tie into the torque boxes (C&T Racing)
Interior:
10pt Custom Roll Cage by C&T Racing Fabrication (runs through dash, very nice)
Custom Sheet metal partition
5 gallon fuel cell installed in place of spare tire well (very trick, spare tire hole has been completely cut out and sheet metal is in place, tons of room under rear, its awesome)
Brand new Carpet, front and back.
Brand new Corbeau Forza Racing Seats with sliders
Clarion CD Player w/ cervin vega speakers and a Clarion Amp
Cables have been run to put battery in trunk, including a battery cut off switch
160mph speedometer
Weld Prostar 15x3.5 upfront (brand new)
Weld Prostar 15x8 or 15x10 out back (your choice, brand new)
Tires are whatever I have laying around :)
This car is very solid and a kickass foundation for anything. I am looking for $3800 for this setup and I am pretty firm. I have invested much much more than this. The rearend and the cage are worth this price alone, and that is not a stretch of the truth in anyway. I just don't have the time for it anymore, and I'm leaving for the military in September, and my parents harass me daily about it being in the way etc etc etc. So anyway, if anyone is interested in this car let me know. I promise you won't be dissapointed.
I am in Houston, TX and I have some pics of car. Thanks alot. Don't email me unless you are interested please.
Mike Reese
Houston, TX
