1 - 1 of 1 Posts
I have a California 88GT mustang forsale. The motor is stock. Car is white. Needs paint. Interior is PERFECT. Here is a list of mods below
Front Susp.
D&D tubular k-member, grondpounder a-arms, and griggs coil overs w/ 200lb springs
5way adj. Tokico drag Struts
Central Coast BumpSteer Kit
Manual Steering with Flaming River Shaft
Central Coast Mustang Camber Plates
Wilwood 12" drag brakes-brand new rotors and pads
Rear Susp.
Bennet Racing Double Adjustable Uppers w/ solid bushings
UPR single adjustable lowers with solid bushings
8.8 w/ 3:73's
Solid rear end bushings (lower control arm)
brand new gt springs w/ poly retainers
Tokico 5 way adj. Drag Shocks
31Spline moser axles
31spline traction lock
fRpp Aluminum driveshaft
Torque boxes fully welded
MISC.
Carbon Fiber Cowl Hood
Cervini Cobra Rear Bumper Cover
MSD Digital 6 w/ 2 step
Driveshaft safety loop
Grant Steering Wheel
Steeda Chromol Subframe Connectors
Battery relocated to hatch with custom Battery Box
No AC at all
5"tach
2 5/8 oil pressure
2 5/8 water pressure
Brand New Weld Draglites 15x8 w/ 5.5 backspacing and 15x4 w/ 2.25 backspacing
Brand New Nitto Extreme Drag 275/50
Brand New MickeyThompson Front Runners
Bassani highflow cat x-pipe
Dynomax mufflers w/ turndowns
Brand new Carpet, front and rear.
Rear Seat Delete
Brand new Fully Reclinable racing Seats
Kenwood Cd Player with Eclipse speakers
30lb injectors
255lph fuel pump
C&L 76mm mass air with inlet tube
Kirban adj. Fuel pressure regulator
Fluidyne aluminum radiator
Underdrive pulleys
Mark VIII electric fan-thermostatically controlled
180degree T-stat
Car could use paint but is perfectly fine as is. Body is perfectly straight save 1 tiny quarte size ding. Car is solid. Ready to run. This is the foundation for one kick ass car, or you can run it as is an have LOW 13second/High 12second Stock motor stang. Asking Price $5000. Car is located in Houston, TX New seat are not installed but they are included. Car is ready to sell now with the exception of a AC delete pulley which I will buy and install. Car is a 5speed car, stock t-5 with short throw shifter. Zoom Kevlar Clutch. Tranny shifts fine normal driving. Spirited driving grinds slightly. Could use new synchros but is perfectly driveable as is and grind free if you are driving normal. Thanks everyone.
Mike Reese
Houston, TX
No Pics At this time
1 - 1 of 1 Posts
