1 - 1 of 1 Posts
There is a reed valve switch (located under the fluid resevoir bottle on top of the master cylinder) to signal low brake fluid in my 87 5.0 master cylinder. When I replaced the master cylinder, I broke the three wire plastic plug going to the switch and can not tell which wire goes where! There are three wires (one gray, one black,one brown). From the fire wall forward, what is their order?
1 - 1 of 1 Posts
