1 - 12 of 12 Posts
85 gt. Manual door car. All new Bright Atlantic Blue paint done correctly with quality materials . Body and paint are close to perfect. Engine bay has been smoothed and painted, underneath has all been painted also. Almost everything but interior is new or close to new . Grey Interior is decent . New headliner.
All the weather striping and moldings new.
Complete drivetrain is fresh, new Motorsport flywheel ,clutch , aluminum driveshaft. Welded subframe connectors , 8.8 completly rebuilt with new bearings , clutches and 373 gear installed. Rear brakes, wheel cylinders and drums are new.
T5 was rebuilt with all the upgraded parts. Tri Ax shifter.
Very low mile Dss 306 with Main girdle , trickflow cam ,fresh gt40 p heads with new valves and spring kit.Has the correct FMS stainless headers, new h pipe , flowmasters and Stainless tail pipes.Holley 650 carb & Stealth intake. New aluminum radiator, electric fan. New distributor & ignition box.
Motorsport lowering springs.
17 cobra wheels with less than 1k miles. Tons more but you get the picture. I have almost everything to finish it . I have most of the receipts and all the build pics. It does need finished being buttoned up. $9000 will also trade.
Located in Cincinnati
Still have ? Located in Lima. Text or call 567 825 7811. Id like to make a offer on it.
17 cobra wheels with less than 1k miles. Tons more but you get the picture. I have almost everything to finish it . I have most of the receipts and all the build pics. It does need finished being buttoned up. $8500 will also trade.
Very nice!!!!!
1 - 12 of 12 Posts
