I'm going to be replacing my stock wires. Any advantages of going w/ 10mm wires instead of the 8.5mm MSD's I am planning to get?
The 8.5's will go back in like stock if you are still using the cover in the valve cover. The 8.5's work well for me! caution when pluging into coil packs try not to take the wire on and off of the coil pack its a tight fit and you may break the plastic clip so no on and off stuff. just do it and be done!
